Error in CFX for conjugate heat transfer problem
    • weij2018
      Hello there! I am doing a conjugate heat transfer project of gas-turbine. After about 600 iterations, the ANSYS CFX solver has terminated without writing a results file, and shows this error in cfx5solve.Please any one give me the solution.
    • rahul.kumar
      I would suggest to start off with a small value of time scale and then gradually increase it.
    • weij2018
      Thank you, sir. After I changed the Timescale Factor from 1 to 0.5, the problem was solved.
  • The topic ‘Error in CFX for conjugate heat transfer problem’ is closed to new replies.
