May 2, 2022 at 1:06 am
nandacd
SubscriberImporting one geom object per program-controlled and one zone per body ...
ERROR:root: No module named 'pwd'
An internal error occured. Please report all the output from the program,
including the above traceback, to ANSYS.
Error: Error in CAD Import
Error Object: #f
Error: Error occurred during import.
Error Object: #f
Error: Importing the selected file could not be completed. Check to make sure that the selected file format is supported. In addition, check to make sure the CAD Readers are properly configured for the format using the CAD Configuration Manager utility.
Error Object: #f
This is the error I have been getting when I import my geometry.
Any help will be highly appreciated.
May 2, 2022 at 12:31 pmSVV
Ansys EmployeeHi Is the geometry created in Spacecliam? Are you trying to import a 2D geometry?
May 3, 2022 at 10:56 pmnandacd
SubscriberIt is a 3d scanned stl which I have converted to solid in spaceclaim and added an enclosure and force shared topology.
Viewing 2 reply threads- The topic ‘Error in CAD import into fluent meshing from spaceclaim geometry’ is closed to new replies.
3897
1414
1256
1118
1015
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
