September 13, 2024 at 6:54 am
shravan.bharadwaj7
SubscriberI have a 2D rectangular grid with 100 mm x 50 mm. When I use the report definition of area, I get the area to be 22.5 m2 instead of 0.005 m2 (100 mm x 50 mm = 5000 mm2 = 0.005 m2). What is the error here ?
This is an air bearing grid. I am computing the area integral of static pressure to get load capacity.
September 13, 2024 at 9:32 am
Petros
Ansys EmployeeHi, can you try using Volume report definition and see if you get the correct area?
