February 10, 2023 at 8:28 pm
dxc200018
SubscriberI get this error when trying to run an FSI simulation in the tutorial pack .
/petastore/ganymede/home/SoftWare/List-Of-Software/Ansys-2022R2/v222/fluent/fluent22.2.0/lnamd64/3ddp_node/fluent_mpi.22.2.0: error while loading shared libraries: libansysfluidshdfsdk.so: cannot open shared object file: No such file or directory
This happens when I load Fluent. What causes this and could you advice on a fix?
February 21, 2023 at 3:00 pm
Hunter Wang
Ansys EmployeeCheck if environment variable I_MPI_ROOT is set, if so unset it and try again.Â
March 2, 2023 at 7:31 pm
dxc200018
SubscriberI tried that , but it still doesn't work. Do you have other suggestions?
March 2, 2023 at 7:41 pm
Hunter Wang
Ansys EmployeeHere is what I found in a launched Fluent v222 console:Â
>!ldd /apps/ansys_inc/v222/fluent/fluent22.2.0/lnamd64/3ddp_node/fluent_mpi.22.2.0 | grep libansysfluidshdfsdk.so
    libansysfluidshdfsdk.so => /apps/ansys_inc/v222/fluent/lib/lnamd64/libansysfluidshdfsdk.so (0x00007fe31c951000)make sure /petastore/ganymede/home/SoftWare/List-Of-Software/Ansys-2022R2/v222/fluent/lib/lnamd64/libansysfluidshdfsdk.so exists, if not check /petastore/ganymede/home/SoftWare/List-Of-Software/Ansys-2022R2/install.log and install.err, restall.Â
Run below, copy and paste output messages:Â
/petastore/ganymede/home/SoftWare/List-Of-Software/Ansys-2022R2/v222/fluent/bin/fluent -env
Also try:Â
/petastore/ganymede/home/SoftWare/List-Of-Software/Ansys-2022R2/v222/fluent/bin/fluent 3d -t2 -g
- The topic ‘error in Ansys Fluent related to libansysfluidshdfsdk.so’ is closed to new replies.
5804
