September 23, 2023 at 7:53 pm
September 26, 2023 at 9:24 am
Ivonne Marti
Ansys EmployeeHi OlhA,
Please find below for the list of the usual culprits for this “COM engine” issue:
1. Verify that CPU and RAM were not at 100% at the time of the error message. Also make sure that hyperthreading is disabled.
2. Ask IT to add security (anti-virus, firewall, etc.) exceptions to AnsysEM folder to ensure that they don't interfere with ANSYS processes.
3. Don’t connect to both Wi-Fi and LAN at the same time and don’t switch network.
4. Don't connect to VPN or connect, then disconnect. If connect, then disconnect, please reboot or run:
ipconfig /release
then
ipconfig /renew
5. Try extending licensing timeout by setting FLEXLM_TIMEOUT=10000000 environment variable
6. Check with IT if there was network instability around the time of error message
I hope it helps you. Ivonne
- The topic ‘Error in Ansys Electronics’ is closed to new replies.
