August 29, 2024 at 10:15 pm
September 2, 2024 at 6:51 am
Niki Papachristou
Forum ModeratorHi Jong,
Thank you for reaching out to us! I think this has to do with the layer map format and more spefically the file content. Are there 5 columns in the file or otherwise? If you see the last column as the Cadence layer indication, you can remove this column, and try it again.Â
Kind Regards,
Niki
September 5, 2024 at 2:38 am
