TAGGED: -Ansys-Maxwell-electronics, circuit, circuit-design, maxwell
March 17, 2024 at 9:41 am
Mark Himonov
SubscriberHi, I want to simulate the signal from the DD coil of a metal detector. I made DD coils and a model of mine TM-62M under them:
I made a section and put there a terminal on two coils and assigned each terminal an external winding:
I decided to make an external circuit to supply sinusoidal voltages with this scheme:
But when I try to import it (Import Circuit Netlist) I get the following error:
What could be the problem?
March 26, 2024 at 8:09 pm
GLUO
Ansys EmployeeHi,
The circuit is incompelete. For closed coils, the one coil terminal represnt the two ends of the winding, which are the two connector of LTx or LRx in your circuit. You cannot leave one of the connector unconnected.
GL
- The topic ‘Error importing Circuit Netlist, Ansys Maxwell’ is closed to new replies.
5824
