October 13, 2024 at 3:54 pm
October 21, 2024 at 1:47 pm
Federico
Ansys EmployeeHello, you might need to update your CAD Readers.Â
What software and version did you use to create your .iges CAD?
October 22, 2024 at 11:52 pm
kevin.pancardoa
SubscriberHello, I am having the same problem as "phi0984437369". I can import 3D geometries from solidworks using .iges and .STEP file formats. But the problem comes when I try to import 2D geometries. I am using Solidworks 2023, and ANSYS 2024 R2.
October 23, 2024 at 2:03 am
annawhuggins
SubscriberAs with geometry dash scratch challenges, resolving this import issue requires systematic troubleshooting. First, ensure that the CAD file was exported correctly from the original software, verify the file format and version. You need to double check the security issue to get the fastest possible resolution.
February 4, 2025 at 7:09 am
coleharry246
Subscriber@escape road Confirm that the CAD file was correctly exported from the original software and check the file format and version. It's essential to thoroughly review the security concern to achieve the quickest possible resolution.
5649
1885
1404
1303
