3D Design
3D Design
Error: GuiOperation Evaluate
    • kai.goellner
      Error occurred when attempting to evaluate a probe temperature across the full transient range. Many messages generated after error invalidating previously solved physics with multiple initial conditions requiring attention: temperature now shown as undefined.
    • Naresh Patre
      Hello goell003
      This looks like a defect. Is the issue only with probe temperature result or with any other result?
      If you reopen the project and add a new temperature probe, do you see the same issue? If yes, is it possible for you to send the project file for investigating this issue?
    • kai.goellner
      The issue has occurred with multiple temperature probes, but other locations work fine. All probes are able to evaluate at a single time step.
      -Restarted and tried the one of the failing probes again...failed
      -Restarted, deleted the probe, added a new probe (using same location)...failed
      -Restarted, deleted the probe, added a new probe, changed the location by a relatively small amount in one direction...result created
    • Naresh Patre
      Hello goell003
      So, after changing the problem location, result got evaluated successfully. Is my understanding correct?
      Is it possible for you to send the concerned project file to investigate the error you received earlier?
    • kai.goellner
      That is correct. Do you want to send me a fileshare link to my email? I can upload an archive file
    • Naresh Patre
      Hello goell003
      I will send you a Secure Transfer link through separate email for uploading the archive file.
Viewing 5 reply threads
  • The topic ‘Error: GuiOperation Evaluate’ is closed to new replies.
