February 3, 2021 at 6:31 pm
Shiva2810
SubscriberHi
Thanks @nchode for your answer regarding export the full model from Motor-CAD into Ansys 2020R1. When I open the .vbs file, I got the following error:
[error] Maxwell2d solver, process solver2d error: Internal Solver Error:Â 'Geometry does not comply with pure rotation motion! (ErrAngle = 2.5007 degree)'. Please contact ANSYS technical support. (1:12:19 PMÂ Feb 03, 2021)
[error] Simulation completed with execution error on server: Local Machine. (1:12:20 PMÂ Feb 03, 2021)
[error] Script macro error: Simulation for Concordia_IPM_Feb3_ANSYSEM_2D : Motor-CAD Concordia_IPM_Feb3 has failed with execution error. (1:12:21 PM Feb 03, 2021)
Based on other's questions I changed the version of Ansys to 2019R2, but the error is the same. Could you please help me to solve this?
Thanks in advance
February 4, 2021 at 12:09 pmNovember 14, 2021 at 9:21 amarh24
Subscriber.Hi I have the same error when exporting from MotorCAD and it is really is annoying, can help me
I have tested Ansys 2021R1, 2020R2, 2019R3
all gave errors related to mesh I guess
   [error] Maxwell2d solver, process solver2d error: Internal Solver Error: 'Geometry does not comply with pure rotation motion! (ErrAngle = 2.5007 degree)'. Please contact ANSYS technical support. (12:04:08 PM Nov 14, 2021)
.October 25, 2022 at 12:30 pmMaharshi Gohil
SubscriberHI, I am getting the same error. Could you solve it? Thanks
January 10, 2023 at 1:09 amBehnam Mosammam
SubscriberHi,
Mesh > initial mesh settings > use slider> change the resolution by the slider and run the simulation to see if it works, it may take a couple of tries, but it works!Viewing 4 reply threads- The topic ‘Error: ‘Geometry does not comply with pure rotation motion!’ is closed to new replies.
5069
1770
1387
1248
