December 1, 2017 at 3:14 pm
omarjumaah
SubscriberHello everyone,
I have this Error: GENERAL-CAR-CDR: invalid argument [1]: improper list
Error Object: #f
on Anys Fluyent 18. Any one can help please. Thanks
December 1, 2017 at 3:29 pm
December 1, 2017 at 3:39 pm
omarjumaah
SubscriberDear Rahul,
thank you for replying. Actually I tried this solution but it did not work and fix the problem.
December 1, 2017 at 3:45 pm
raul.raghav
SubscriberHave you tried the following as well:
1. Save the case and data file and try to reopen it.
2. Reset the fluent Setup tab and try opening the mesh.
3. Try to remesh the geometry and reopen in fluent.
I hope one of the above works for you. Good luck!
December 4, 2017 at 12:16 am
omarjumaah
SubscriberThank you, I solved it by resetting the setup.
February 25, 2021 at 10:27 am
ramkall
SubscriberI reset the setup and the same problem is resolved. But when I activated the evaporation-condensation as the phase interaction mechanism, the same error appeared again. The geometry is 2D axisymmetric. So it seems that evaporation-condensation in the multiphase mechanism (VOF model) creates a kind of inconsistency with the mesh I have. nWhen I changed the transient to steady, the error was resolved!nComment on this issue is appreciated. nThanksn -
February 25, 2021 at 11:10 am
Forum ModeratorCheck what is set in the various panels. CAR-CDR generally means a setting is missing that is needed. n
Viewing 6 reply threads
- The topic ‘Error: GENERAL-CAR-CDR: invalid argument : improper list’ is closed to new replies.
1771
1387
1248
