March 31, 2021 at 1:29 pm
sudanimal
SubscriberApril 1, 2021 at 10:05 amRob
Forum ModeratorThe problem could be mesh, set up or boundary related. Have you done any of the tutorials? nApril 1, 2021 at 11:10 amsudanimal
SubscriberI think its a meshing problem, and no I have not done the tutorials.nApril 1, 2021 at 11:30 amsudanimal
SubscriberI simulated a single turbine, which worked fine. However when I added the second turbine. I got the error abovenApril 1, 2021 at 11:31 amsudanimal
SubscriberDo you recommend any type of meshing I should do?nApril 1, 2021 at 2:12 pmRob
Forum ModeratorI recommend working through the tutorials and then reviewing what you've done. If one turbine worked, what's different in the set up with two? nViewing 5 reply threads- The topic ‘Error: floating point exception Error Object: #f’ is closed to new replies.
5164
1836
1387
1249
