February 6, 2019 at 10:39 am
CatiaV5
SubscriberHi all,
I'm using spaceclaim to create an enclosure for my geometry. However, when trying to open it in Ansys mesher I get the error "PlugIn Error: Failed to import assembly from SpaceClaim. No bodies to transfer."Â
Can someone help me out on this please? -
February 6, 2019 at 11:49 am
Keyur Kanade
Ansys Employeeis it 2d?
if 2d, make sure that your surface bodies are in xy plane.Â
also go to windows start > cad configuration manager and configure spaceclaimÂ
make sure that you have admin permissions.Â
February 6, 2019 at 1:42 pm
CatiaV5
SubscriberI think the issue is the enclosure. It gives me a warning "an error occurred while creating the enclosure (protruding bodies). Try increasing the cushion value)". I believe it is because of the symmetry plane. It is only half a model so I would like to have only half of an enclosure. Do you know how I can achieve this?Â
February 6, 2019 at 3:45 pm
Forum ModeratorBuild the whole model (and/or enclosure). Then slice the model on the symmetry plane and delete anything you don't need. If you've got the enclosure & symmetry plane in the same location the maths may be getting confused.Â
April 28, 2020 at 7:47 am
hemu93
SubscriberHello,
Create enclosure by ANSYS defaults (whatever the cushion value is, mostly 25%).
Then you delete the portion of the enclosure which you don't want by creating planes/split body tool.
Then using the pull command, set your required enclosure dimensions.
Hope this helps you.Â
August 23, 2021 at 6:32 am
Bob_Wang
Subscriber.Hello,
Make sure the 2-d model in x-y plane,which could solve the problem
December 31, 2021 at 8:51 am
osama_habahbeh
Subscriber.Try this: In Space Claim, Right click the body in the structure tree then Activate for physics.
- The topic ‘Error: Failed to import assembly from SpaceClaim. No bodies to transfer’ is closed to new replies.
3266
1036
1004
859
798
