LS Dyna
LS Dyna
Error encontered in SPG Solid-Thermal Coupling Analysis
    • Zhang Zihui
      Hello everyone, I'm using SPG method for cutting simulation and successfully did solid mechanics simulation, but when I do thermo-solid coupling analysis, I encountered an error in the solution, does anyone know how I should solve it, thanks a lot!
    • Ram Gopisetti
      we have given the support to SPG with Thermal mechanical Coupling Analysis capablities both in SMP and MPP.
      try using the latest solver R14 or higher
      cheers, ram
      • Zhang Zihui
        Thanks, ram. I'm using the R12 solver in MPP, and I'll try the other version.
  • The topic ‘Error encontered in SPG Solid-Thermal Coupling Analysis’ is closed to new replies.
