May 22, 2024 at 6:42 am
May 22, 2024 at 8:13 am
ErKo
Ansys EmployeeHi
It looks ok and I assume there is 1 single part and no contact anywhere (if there are 2 or more parts you need to have contacts).
First try to solve it without distributed solve and not in background.
When you run it and you still get an error see the Solution information for any error msgs (see below how to check that Information).
https://www.padtinc.com/2012/07/12/solution-information-monitoring-your-solves-in-ansys-mechanical/#:~:text=There%20is%20a%20folder%20with,the%20ANSYS%20Mechanical%20APDL%20solve.
Thank you
Erik
May 22, 2024 at 10:49 am
- The topic ‘Error During solving the Probelm’ is closed to new replies.
1307
