March 15, 2024 at 10:27 am
Luiza Oltean
SubscriberHello everyone! I am doing a coupled transient electro-thermal simulation in the coupled field module in workbench r2023r1. I have automated the entire simulation with python scripting  and during restart I use apdl commands to change the rezistivity of certain elements at a certain step  then solve again. Unfortunately i encounter an error that only appears as a warning in the interface as seen in the image and it is not detailed in the err file or anywhere else.Â
Here is the code i am using to do the restart. command 2 is created before the restart to avoid creating it again and again.Â
Has anyone encontered this problem? I read some posts about the rst file that has to be disposed of before another solve or that it may be a bug. Any suggestions would be great. Thank you#SET THE ANALYSIS TO RESTART
settings.RestartType=RestartType.Manual
settings.CurrentRestartPoint=1
step_index_list=list(range(1,settings.NumberOfRestartPoints+1))
with Transaction():
  for step_index in step_index_list:
    settings.CurrentRestartPoint=step_index
    vartest=1
    while(vartest < 3):
      vartest=vartest+1      #COMMAND INSERTION FOR RESISTIVITY
      command_1=solution.AddCommandSnippet()
      command_1.StepSelectionMode=SequenceSelectionType.ByNumber
      command_1.Name="Det_resistivity"
      command_1.Input="""
/PREP7
*DEL, transistor_model, , NOPR
*DIM, transistor_model, TABLE, 161, 39, 69
*TREAD, transistor_model, 'TableModel', 'table'/INQUIRE,numlines,LINES,'ELEM_T_VDS_VGS_file_multipleT_restart','txt'
*DEL,mytable,,NOPR
*DIM,mytable,TABLE,numlines-1,9,1 !Â*DEL, final_val, , nopr
*DIM, final_val, ARRAY, numlines-1,7,1Â*TREAD,mytable,'ELEM_T_VDS_VGS_file_multipleT_restart','txt','',,
!*STATUS,mytable*DO,i,1,numlines-1
  *VITRP, final_val(i,2,), transistor_model, mytable(i,8,1), mytable(i,2,1), mytable(i,7,1)
  *VITRP, final_val(i,3,), transistor_model, mytable(i,8,1), mytable(i,3,1), mytable(i,7,1)
  *VITRP, final_val(i,4,), transistor_model, mytable(i,8,1), mytable(i,4,1), mytable(i,7,1)
  *VITRP, final_val(i,5,), transistor_model, mytable(i,8,1), mytable(i,5,1), mytable(i,7,1)
  *VITRP, final_val(i,6,), transistor_model, mytable(i,8,1), mytable(i,6,1), mytable(i,7,1)
  *VITRP, final_val(i,7,), transistor_model, mytable(i,8,1), mytable(i,7,1), mytable(i,7,1)
*ENDDO*CFOPEN,'interpolated_val_restart','txt'
*VWRITE,final_val(1,3,1),final_val(1,4,1),final_val(1,2,1),final_val(1,5,1),final_val(1,6,1),final_val(1,7,1)
%G,%G,%G,%G,%G,%G
*CFCLOSFINISH
/SOLU"""
      solution.ExecutePostCommands([command_1])
      #Define the named sel from interface for substrate_elements
      command_2.Name="MP_change_Command"
      command_2.Input="""
/PREP7*SET,maxelement,15355
!Read material property txt data
*DIM,cond,TABLE,maxelement,1,0, , , Â
*TREAD,cond,'interpolated_val_restart','txt',' ', ,/INQUIRE,numlines,LINES,'ELEM_T_VDS_VGS_file_multipleT_restart','txt'
*DEL,mytable,,NOPR
*STATUS,mytable*DO ,i,13367,maxelement,1
!ESEL,S,elem,,i
EMODIF,i,MAT,i
MP,KXX,i,280
MP,DENS,i,2358
MPTEMP
MPTEMP,1,mytable(1,3,1),mytable(1,4,1),mytable(1,2,1),mytable(1,5,1),mytable(1,6,1),mytable(1,7,1)
MPDATA,RSVZ,i,1,cond(i,0),cond(i,1),cond(i,2),cond(i,3),cond(i,4),cond(i,5)
!EMODIF,i,MAT,i
*ENDDO
FINISH
/SOLU"""
      command_2.StepSelectionMode=SequenceSelectionType.ByNumber
      command_2.StepNumber = step_index
      command_1.Delete()
      model.Solve() -
March 18, 2024 at 7:22 am
Derrick Rogers
SubscriberÂ
I think you should consider disposing of the .rst file. As you mentioned, it might be worth trying to dispose of the .rst file before performing another solve. You can use an APDL command like /INPUT, filename.rst to read the .rst file and then issue a /SOLU, PREP7 command to reset the solution environment.Â
- The topic ‘error during restart of a electrothermal analysis’ is closed to new replies.
