July 6, 2020 at 3:38 pm
ecrod
SubscriberHello All,
Every time I try to close Fluent session I receive this message : Posting ANSYS Product Improvement Program performance data
Done.
And after two minutes:
0: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
2: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
3: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
4: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
5: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
6: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
7: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
8: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
9: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
10: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
11: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
12: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
13: 120 seconds have elapsed since the calling of MPI_Finalize, so Fluent node process will be forced to exit!
MPI Application rank 0 exited before MPI_Finalize() with status 0
The fl process could not be started.
I am running in parallel with 14 cores. What could be a cause for this error message ?
Thanks in advance.
July 6, 2020 at 5:24 pm
Rahul Kumar
Ansys EmployeeHello,
Which version of Fluent are you using?
July 6, 2020 at 5:47 pm
ecrod
SubscriberI have been using version 2019 R2 academic.
July 6, 2020 at 6:41 pm
Rahul Kumar
Ansys EmployeeDo you get any error while running in serial?Â
July 6, 2020 at 6:48 pm
ecrod
SubscriberI got this error in serial:
Done.
It have been happening only when I try to close session. During calculation everything is ok.
July 6, 2020 at 7:58 pm
Rahul Kumar
Ansys EmployeeIs this with just one particular simulation or does this error occur with any simulation model? Also, can you please update to Ansys 2020 R1 and try again?Â
July 6, 2020 at 8:52 pm
July 7, 2020 at 4:50 am
Amine Ben Hadj Ali
Ansys EmployeeBoth pictures correspond to different version. Clean uninstall and install as root. Check installation log files. -
July 7, 2020 at 10:53 am
ecrod
SubscriberAbenhadj,
I did not understand. Both pictures shows 2019 R2 and R19.2 versions.
Why are different ? In this case, which is the version of each ?
Thanks.
July 7, 2020 at 2:54 pm
Rahul Kumar
Ansys EmployeeYes, both are 2019 R2, the first picture is when you open Fluent through workbench and the next one is a standalone version. What Amine is suggesting is to uninstall Ansys from the start menu and also delete any related folders or files (not the simulations) and install again (make sure you choose "run as administrator".Â
July 7, 2020 at 3:04 pm
ecrod
SubscriberÂ
I believe that the problem was solved after install updates in my Windows.
I am not receiving this messages anymore when Fluent session is closed.
Thanks
July 7, 2020 at 5:02 pm
Rahul Kumar
Ansys EmployeeAwesome! Please mark "Is Solution" so that other members in the community can be benefited.Â
- The topic ‘Error during close session of Fluent’ is closed to new replies.
- affinity not set
3912
1414
1256
1118
1015
