May 9, 2023 at 1:07 pm
Lukas Hildebrand
SubscriberDear community,
I coupled my EddyCurrent Design with Icepac and everything works except for Errors in the 3D Model which name as follows:
1) Duplicate Face ID (XXXXX) found in part XXX
1) Duplicate Edge ID (XXXXX) found in part XXX
1) Duplicate Vertex ID (XXXXX) found in part XXX
What does that mean and how can I resolve them?
Thanks,
Lukas
May 11, 2023 at 11:13 am
Pdev
Ansys EmployeeHi Lukas,
Could please share screen shots of this error? and is the simulation running?Â
Best,
Pdev -
May 24, 2023 at 4:26 am
Pine Liu
Subscriberwhat is answer?
May 24, 2023 at 7:23 am
Lukas Hildebrand
SubscriberHi Pine,
the problem was that somehow the Icepac designer did not like a specific model that was duplicated around an axis and apparently gave the same id's to the duplicated one. I solved the problem by not duplicating the model around the axis, but modeling it again the same way I designed the original model.
Hope this helps.
Lukas
September 4, 2023 at 6:50 am
Thermal Xiaomi
apparently, i got the same error when I was trying to generate mesh for a MCAD model. However, the MCAD model is quite complicated and it is accomplished by another department, namely, almost impossible to fix the issue with the method metioned by Lukas to just adjust the way of modeling.
So, is it possible to fix this duplicate face/edge error by some operation in Spaceclaim or AEDT icepak?Â
BestÂ
Xiaomi
- The topic ‘Error Duplicate Face/Edge and Vertex ID with Icepac coupling’ is closed to new replies.
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
3862
1414
1221
1118
1015
