Error: domain-var-value: undefined variable
    • abarr5050
      Does anyone know what this error means...
      Error object: pb/sg-pb-dqmom
      It will still let me run the simulation but this error pops up a bunch of times when I open "Setup" and then after initialization.
      -thanks
      It means you've missed setting something in the Population Balance model somewhere.
    • abarr5050
      I do not believe I am using a Population Balance model...unless it is automatically set with the mixture model. Where can I find settings for this model?
      How did you set the second phase diameter?
    • abarr5050
      I left it as the default 1e-05 and as a constant. Would you recommend I change this?
Viewing 4 reply threads
  • The topic ‘Error: domain-var-value: undefined variable’ is closed to new replies.
