Electronics
Electronics
Error: “….does not support SOLID117…”
    • momidor
      Hei to All,
      Does the someone can prompt me how to solve hereunder error in very simple magnetic model of the standalone simulation?
      Thanks in advanced.
      "The Distributed ANSYS solution does not support SOLID117 elements.
       Distributed parallel processing will be deactivated for this solution. "
    • Khadijah
      I am having the exact same error, is there any way you were able to solve the issue?n
  • The topic ‘Error: “….does not support SOLID117…”’ is closed to new replies.
