3D Design
3D Design
Error deleting a view in drawing sheet
    • Andrea Ventura
      ? This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello, here the bug in the new 2021 R2: With several already saved assemblies when user delete a view it get an error on delete process and the view is still visible until the user zoom in/out, then disappears but it still remains in structure tree. After that sometimes reopening the file you get a "red icon" grafic problem and you should restart SpaceClaim. A customer discovered this bug with his file, then I tried with several file with the same problem (working file in R1 version). Obviusly the bug fix is urgent. I'm sending a test file privately.
    • subashni.satish
      Hello DrkAngl
      Thanks for reporting this. This definitely looks like a bug.
      I have emailed you a link, please use the link to share the file via Secure transfer.
    • Andrea Ventura
      I sent you a sample file
    • Andrea Ventura
      Hello Subashni Subashni, any news?
    • subashni.satish
      DrkAngl BUG number 517879
Viewing 4 reply threads
  • The topic ‘Error deleting a view in drawing sheet’ is closed to new replies.
