October 26, 2021 at 9:46 am
yann
SubscriberHi,
I've a little problem using Spaceclaim, an error appear when I want to cut a body. I've read a similar question but it's not working for me.
The error might come from that I've imported a .iges geometry then when I try to cut it on Spaceclaim it doesn't work.
Either way by sharing the topology or not it's not resolving my error.
October 27, 2021 at 11:48 amAniket Chavan
Forum ModeratorI am sorry my French is as good as Google can translate, but can you try another plane instead of the one passing through the YZ plane? do you have the same behavior then.
Instead of using split bodies, have you tried to split faces? and then detach the faces so that you can create separete bodies?
-Aniket
October 28, 2021 at 10:20 amyann
SubscriberHi, It works thanks!
Yes it was the same for all the planes, I don't understand why it woks by splitting face instead of body directly :/ but it least i can go forward
Viewing 2 reply threads- The topic ‘Error cutting body’ is closed to new replies.
