April 18, 2020 at 1:24 pm
havrilovjonh94
SubscriberRecently, I`ve installed Ansys Student 2019R3. Workbench lanches and works fine, made a Geometry in SpaceClaim, but Model was not responding even after 30 minutes. Then I closed Mechanical window and received this message:
System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 127.0.0.1:63285
April 20, 2020 at 7:04 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.Â
This may be installation issue. moving to installation category.Â
April 20, 2020 at 4:11 pm
April 23, 2020 at 7:08 pm
tsiriaks
Ansys EmployeeTry thisÂ
move "%appdata%ansys" "%appdata%ansys.old"
in CMD Prompt window.
If that doesn't help, try suggestions in this
/forum/forums/topic/installation-issues-and-starting-problems-geometry-editor/
April 29, 2020 at 4:32 pm
havrilovjonh94
Subscriber -
April 29, 2020 at 9:51 pm
tsiriaks
Ansys EmployeeHi Havrilov,
Can you try temporarily turning off all of your security on the machine ?
Are you using VPN ?
What graphics card do you have on the machine ? Try updating your graphics driver.Â
Try manually register the DLLs listed below by starting a Command Prompt (DOS) with "run as administrator" , then typing:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
make sure they all say succeed
Check the PATH System Variable to make sure that C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;… entries are in front of everything else.
Like: PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;…all other entries...
Run the ProductConfig.exe fromÂ
ANSYS Incv###Â Â and configure the application again, by right-clicking the productconfig.exe file and select "Run as Administrator" >> "Configure Products & CADs" >> select all options.
May 1, 2020 at 11:47 am
May 6, 2020 at 9:32 pm
tsiriaks
Ansys EmployeeGreat ! Glad it's working for you now !
Win
- The topic ‘Error! Conversion Failed. Either the application crashed or Workbench lost communication with it.’ is closed to new replies.
3862
1414
1221
1118
1015
