January 10, 2024 at 6:42 pm
Emma Hughes
SubscriberI am following ch5 in the UDF manual to link pre-compiled object files to the library in the VS command prompt for windows. when I execute the makefile I get these errors where it cant read my header files:
 cl : Command line warning D9024 : unrecognized source file type '..\..\src\header_external_calcs.h', object file assumed
cl : Command line warning D9027 : source file '..\..\src\header_external_calcs.h' ignoredI beleive they are included correctly at the top of both my main.c file and my external.c file that i have apready compiled into external.obj. i have the external.obj, user_nt.udf, and makefile in the ..\libudf\win64\3ddp_host and main.c and header_external_calcs.h in ..\..\src folder.Â
this is what my user_nt.udf file looks likeÂ
CSOURCES = $(SRC)main.c
HSOURCES = $(SRC)header_external_calcs.h
VERSION = 3ddp_node
PARALLEL_NODE = smpi# Do not change the following line unless externally precompiled objects
# Â are to be included at the linking stage.
# Â For example: USER_OBJECTS = my_fortran_funcs.objUSER_OBJECTS = external.obj
does anyone know why I am getting these errors?
April 11, 2024 at 12:59 pm
Luca B.
Forum ModeratorHi, it is not simple to provide an answer without seeing the files. There could be probably an error in the source files.
Do you compile them with the same compiler version?
I invite you to visit the following page with more information about the commands 5.3. Compile a UDF Using the TUI (ansys.com)
- The topic ‘error compiling UDF with personal header file’ is closed to new replies.
3139
1007
918
858
792
