October 13, 2020 at 5:12 am
user deleted
SubscriberHello everyone.
During static mechanical calculation I got the following error.
Could anyone know what to do with that?
October 13, 2020 at 7:24 amAniket
Forum ModeratorHi!nCan you please provide some more info about this error:nHow many cores are you requesting?nDo you have that many cores dedicated and available?nHow many physical cores your machine has?nGenerally, if your machine has 6 cores, keep couple of free and use only four for your runs, as these 2 cores will be used for I/O as well as other programs. If you are already doing this and still seeing it let us know more details! Also, just a suggestion, you can use snipping tool to take screenshot on the machine you are working with!n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnOctober 13, 2020 at 8:24 amOctober 13, 2020 at 3:09 pmAniket
Forum Moderatorare you the only user of this machine? It happens that others try to access the machine and cores that you have assigned to solver are grabbed by other processes. nCan you try to:nmake sure that no other users are accessing the machine.ntry with less number of cores if possible.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnOctober 14, 2020 at 1:58 pmuser deleted
SubscriberAniket hello.nUnfortunately it didn't help. nOctober 14, 2020 at 2:18 pmAniket
Forum ModeratorGordievsky87, so using less cores results in this error still? How many did you try? I am sorry I do not have any further suggestions as this error is given by the OS to APDL and that has been passed down to solver output.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning ForumnViewing 5 reply threads- The topic ‘Error code =87’ is closed to new replies.
4613
1520
1386
1209
