October 25, 2021 at 1:50 pm
Michael93
SubscriberHallo Liebe Forumsmitglieder, ich habe folgenden Fehler(Siehe Bild):
October 26, 2021 at 2:21 pmPraneeth Munaga
Did you check whether you have sufficient RAM availability to run the simulation?
Best regards.
October 27, 2021 at 9:11 amMichael93
SubscriberThis pc has 192GB RAM, but it is possible that most of it is used from other users. I have to find out where i can check the available RAM. You are sure that causes the error?
October 27, 2021 at 10:35 amPraneeth Munaga
The issue would be with memory on your system.
Can you check whether you have enough disc space or not in the location of simulation model?
Or else you can check with a location where you have enough disc space.
All the very best.
Viewing 3 reply threads- The topic ‘error closing file %1’ is closed to new replies.
6790
1331
1147
