August 9, 2023 at 5:08 am
Dana Kang
SubscriberHi, I'm currently designing a simple flow design using porous media (metal foam), and it shows me the error below when I set the cell zone condition for the metal foam :
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
Above are the settings I used for the metal foam porous zone, and it displays the error when I click 'Apply'.
Any help would be appreciated. Thank you in advance!
August 9, 2023 at 1:33 pm
Forum ModeratorIt usually means there's a blank field somewhere, ie something is missing from the set-up. Check the remainder of the panel, but there is a slight chance you've turned something on/off earlier in the set-up and corrupted a value call in the GUI. See if turning some of the options on/off clears the issue.Â
The changed settings report, Input Summary > List Changes can help if you look for empty fields.Â
August 10, 2023 at 2:59 am
Dana Kang
SubscriberHi Rob,
Thank you for your reply. I checked the modified settings summary and it shows a note that ‘Reinjected particles do not change their injection association’ and a random value.
Could this be what’s causing the error? If so, would there be any possible ways to solve this?
Thank you in advance.
August 10, 2023 at 8:01 am
Forum ModeratorDon't think so, but it's something to switch off before trying the porous zone again.Â
Double check what your interface zones are for: did you check the nonconformal set up?
September 6, 2023 at 1:30 am
September 11, 2023 at 11:43 am
Forum ModeratorThat looks like you don't have any. That may be correct for the non-equilibrium model, but if you read up on https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v232/en/flu_ug/flu_ug_sec_grid_nonconform.html especially 6.6.4.1 you can switch to the manual mode and double check.Â
September 21, 2023 at 2:31 am
September 21, 2023 at 7:57 am
Forum ModeratorAccording to that list there are no interface zones either. Have you read a new mesh into Fluent in Workbench, or by re-reading the grid? I'm wondering if something has got scrambled or corrupted in the set up.Â
September 26, 2023 at 3:48 am
Dana Kang
September 26, 2023 at 12:53 pm
Forum ModeratorI'm not permitted to download anything.Â
The foam volume will be created in Fluent when you turn on the non-equilibrium model, so you should just be importing fluid, fluid-porous and casing as zones (2 fluid & 1 solid). The porous "solid" is set by Fluent, and you shouldn't need to interact with that.Â
- The topic ‘Error: CAR: invalid argument [1]: wrong type [not a pair]’ is closed to new replies.
5944
1307
