Photonics
Photonics
Error: can not package/publish the selected node
    • Peter DeVore
      Hi all,
      Made a new INTERCONNECT file, right clicked the Custom folder, hit Package/Publish, get an error message: "Error: can not package/publish the selected node." Any hints on how to debug this?
      As a side note that might be related, I cannot open the CML Compiler tool. When I click it, it creates a window that is blank and whose window doesn't show up.
      Thanks,
      Peter
    • Dev
      Hello Peter,
      Which version of software are you using?
      Please share screensots of error.
      Regards
      Devika
    • Peter DeVore
      Hi Devika,
      Please see below.
      Thanks,
      Peter
      P.S. As a side note, for some reason, CML Compiler now opens; if it stay that way no longer an issue. I did not change anything to the best of my knowledge to get this to happen.
    • Dev
      Thank you for shairing more information.
      Can you try crating a new folder inside custom folder. Save the new element you created inside that folder. Then try to publish it.
      So you have right click on the new folder -> select package or publish.
      Please let me know if that solve the issue.
      Thanks and regards
      Devika
    • Peter DeVore
      Hi Devika,
      Thanks that worked. Does that mean that right clicking on Custom itself is not supposed to work? Should this text:
      "To package/publish a compact model library, users can simply right click on the "Custom" folder in the Element Library (or a subfolder within) and select "Package/Publish" option"
      be updated to:
      "To package/publish a compact model library, users can simply right click on a subfolder in the "Custom" folder in the Element Library and select "Package/Publish" option"
      in:
      https://optics.ansys.com/hc/en-us/articles/360036620293-Package-Publish-Compact-Model-Library
      Thanks,
      Peter
    • Dev
      Hello Peter,
      Yes, you're correct. Only subfolders within the Custom folder can be published.
      Thanks for pointing that out in the manual page. The page has been updated.
      I am closing this post.
      Regards
      Devika
Viewing 5 reply threads
  • The topic ‘Error: can not package/publish the selected node’ is closed to new replies.
