March 21, 2025 at 4:19 pm
varad.takke
SubscriberI have a 3D complex assembly with multiple subassemblies on which I am running an airflow simulation for which I am using the Icepak Standlone system. My mesh doesn't have any negative volumes, inverted blocks, zero slack, assembly interferences, no overlaps but still when I run the solution on parrallel as well as serial I get the Error mentioned in the title. How can I find where the issue is?
March 24, 2025 at 1:44 pm
Pdev
Ansys EmployeeHi Varad,Â
Thanks for reaching out! This issue could be related to your mesh. I recommend experimenting with different meshing strategies. You might start by simplifying the assemblies and checking if that resolves the problem. From there, you can gradually increase the model's complexity.
Best,Pdev
March 24, 2025 at 5:02 pm
varad.takke
SubscriberSo Icepak isnt able to create a grid with the minimum gap less than 0.8 mm. If I keep the minimum gap as 0.8 mm the simulation runs without any errors. How would you suggest going about selecting minimum gap for a very complex model with multiple areas where variable minimum gap exists ?
March 24, 2025 at 5:26 pm
Pdev
Please try with enabling the "Allow minimum gap changes".Â
Best,
Pdev -
March 24, 2025 at 5:36 pm
varad.takke
SubscriberIs there a way I can predetermine which mesh settings will fail or determine the best settings before I run the solution?
- Plotting Ex, Ey and Ez in vector forms individually
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Maxwell circuit – PWM
- Y wiring method and the start and end points of winding.
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
2738
959
824
599
591
