TAGGED: boolean-error, designmodeler, foot, unite-boolean-operation
February 18, 2022 at 4:36 pm
yann
SubscriberHello,
I don't understand why I'm having the following error :
February 20, 2022 at 4:39 pmpeteroznewman
SubscriberIt might help if you edit the bone solid first. Make a Plane and create a clean cut at the top to remove the rounded edges. You can use Pull to move the top of the bone up some until it rises above the top of the foot.
Do the same for the foot solid. Having one end of the bone solid cleanly rise about the foot solid may help the Boolean operation to succeed.
February 21, 2022 at 3:04 pmyann
SubscriberThanks to your answer I understood that it didn't work because my bones are made with tomography. I think it should work if I mesh them before the boolean operation (it works as you can see in the previous picture for those who were meshed before). However can I mesh a body in design modeler ? I've seen that is possible in spaceclaim but I hope i can do that on design modeler
February 21, 2022 at 6:08 pmpeteroznewman
SubscriberIn geometry, you need a foot with bone-shaped cavities in it. This is done before meshing. You must do the boolean subtract before you mesh the foot, otherwise the mesh will overlap with the bones when you mesh those.
February 23, 2022 at 3:40 pmyann
SubscriberHi, thanks for your advices it helps!
My boolean substraction works for the bones by simplifying before their geometry and topology. Indeed I've used extrusion to the top of the tibia, instead it wasn't working.
Viewing 4 reply threads- The topic ‘Error boolean substraction on design modeler’ is closed to new replies.
5954
1307
