November 10, 2023 at 5:02 am
Dana Kang
SubscriberHi, I'm currently designing a simple flow design using porous media (metal foam), and it shows me the error below when I tried to run my calculations:
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error at Node 0: Normalized key of 19629220 is out of range [0, 18601095].
Error at Node 6: Normalized key of 19780876 is out of range [0, 18601095].
Error at Node 2: Normalized key of 19686891 is out of range [0, 18601095].
Error at Node 5: Normalized key of 19687374 is out of range [0, 18601095].
Error at Node 4: Normalized key of 19729890 is out of range [0, 18601095].
Error at Node 3: Normalized key of 19629527 is out of range [0, 18601095].
Error at Node 7: Normalized key of 19629224 is out of range [0, 18601095].
Error at Node 1: Normalized key of 19687060 is out of range [0, 18601095].
Checking the case set-up ...
Done
Below is my mesh display in the setup:
I would appreciate any advice or help, thank you!
November 15, 2023 at 2:59 pm
Luca B.
Forum ModeratorHi , cortex errors are typically related to Graphic interface. Anyway the error message seems to be memory related during your parallel run. Are you working with UDF? verify that it is written for parallel run.
If you can arise a support request we can furhter analyze your model.
Luca
- The topic ‘Error at Node -: Normalized key of – is out of range’ is closed to new replies.
