Error at host: Iterate: Uninitialized flow field
    • sarita.mohapatra
      While during run calculation in ansys fluent,the following error is showing
      Message from the Cortex Process
      Compute process interrupted. Processing can be resumed.
      Error: Iterate: uninitialized flow field
      Error Object: #f
      Please help me to resolve this issue as i am new in ansys, i could not find out this solution.
      Did you initialise the flow?
    • sarita.mohapatra
      Yes, i have initialized the flow.
      Any UDFs? Please can you post some images of the interface?
    • Ramkumar Jayaraman
      Error Object: #f
      Have you initialised the flow? Any UDFs?
Viewing 5 reply threads
  • The topic ‘Error at host: Iterate: Uninitialized flow field’ is closed to new replies.
