October 21, 2024 at 11:52 am
OAnderson
SubscriberHi all,
During workflow of a watertight geometry, when generating mesh, I recieve:
Error: arg(2nd) out of range in substring
Error Object: 7
I don't know what this means, and I haven't been able to find further documentation for troubleshooting. I have made sure the length of the part and surface names are longer than 4 characters and do not incude special characters.
Please help!
October 22, 2024 at 2:15 pm
OAnderson
SubscriberTo be more specific:
- I have no issues generating surface mesh during tutorials such as ‘high-speed train geometry’. I’ve also tried generating a cube directly in SpaceClaim, which I was able to mesh in Fluent.
- The part I am trying to mesh was drawn in Inventor and imported to SpaceClaim as a .stp file. From there it is saved as an .sdoc file, so I don’t really see that the original file type should matter.
I’m new to Ansys so any help is greatly appreciated!
October 23, 2024 at 12:43 pm
Federico
Ansys EmployeeHello,
Where in the Watertight Geometry workflow are you getting this error?
Maybe there was an issue in translating the original geometry to SpaceClaim. Can you do a Geometry Check in SpaceClaim to ensure that there are no errors with the model?
November 11, 2024 at 9:00 am
OAnderson
SubscriberDear Federico,
Thanks very much for your advice. Geometry Check uncovered the problem: there was, by coincidence, a curved edge which led to a zero thickness at one point. After fixing this, no more problems.
Thanks!
November 11, 2024 at 1:24 pm
Federico
Ansys EmployeeThanks for your confirmation. Glad it helped :)
