June 21, 2021 at 10:38 am
Dheeraj_Singh
Subscriber -
June 21, 2021 at 12:38 pm
Subashni Ravichandran
Forum ModeratorHello Dheeraj Singh
Would you please share the file with us for investigation?
I have sent you a secure transfer link via email to share the file.
June 21, 2021 at 12:53 pm
Dheeraj_Singh
SubscriberDear Subashni
Done!! Attachment shared.
Dheeraj
June 22, 2021 at 4:44 am
The heat is defined in your model as "total heat" over the selected volume. As the volumes are different the temperatures are proportionately different.
Try defining the heat as "per unit volume".
June 22, 2021 at 9:20 am
Dheeraj_Singh
SubscriberHello Subashni Gave a shot but this is of no good result. Attachment of results present. � This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
June 24, 2021 at 3:20 am
Dheeraj_Singh
Request you to provide update on this work.
June 28, 2021 at 5:13 am
Dheeraj_Singh
Could you please check the model shared in below link.
The model is same for both queries (for this query and different convective inputs query)Â and still we are getting error in Explore stage after applying total heat over selected volume as suggested by you.
Please support.
Dheeraj
July 1, 2021 at 7:25 am
Dheeraj_Singh
The customer is facing the same issue of uneven results for another model as well.
I request you to provide your time availability so that we can have a teams call with customer to observe the error which they are facing.
Dheeraj Â
July 1, 2021 at 12:26 pm
Dheeraj_Singh
Please do simulate this model and inform us the source of error.
Dheeraj
July 5, 2021 at 3:39 am
Dheeraj_Singh
Can we please connect with customer today for a short call over MS Teams?
Waiting for your valuable response.
Dheeraj
July 5, 2021 at 5:49 am
I apologise for the delay. Due to some issue with my machine I was not able to investigate your model sooner.Let us have a call over Teams today with the customer. Please let me know a convenient time for you.Â
(I sit in the India time zone.) -
July 5, 2021 at 8:02 am
Dheeraj_Singh
Thank you so much for your response and support.
Can we plan for this meeting tomorrow(06/07/2021) around 12:30 Pm ?
Please let me know your availability for tomorrow.
Dheeraj
July 5, 2021 at 8:20 am
I have shared a Link to the Teams meet via email for 12:30 pm tomorrow.Â
Please let me know via email if you face any issues accessing the link.
July 6, 2021 at 7:51 am
Thank you for joining the call.
As discussed it is advisable to run the simulation with lesser components in Explore mode in the interest of better fidelity for the simulation. I will share our observation with my team regarding the temperature profile observed.Â
I will run the simulation in Refine mode as well and check for the results. Please let me know your results as well. -
July 8, 2021 at 3:23 am
Dheeraj_Singh
Request you to share secure link to send model of Refine mode.
Dheeraj
- The topic ‘Error appears in results in explore stage’ is closed to new replies.
- Add-in Error Excel
- Spaceclaim problem
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- New Computer
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
- Unable to attach to geometry file 2025R2
- How would I select specific components and all bodies under it?
4633
1535
1386
1225
