October 19, 2023 at 8:50 pm
J.Benavides
SubscriberI am performing a welding simulation (coupled thermal-structural analysis), it's a transient analysis (50 load step). In the last load step in the structural part, I perform a re-start to change the boundary conditions of my geometry. When I try to read the results, I get the following error message for each load step prior to the last one (50):Â
 *** WARNING ***             CP =   2503.844  TIME= 22:09:32
 Cumulative iteration XX may have been solved using different model or  Â
 boundary condition data than currently stored.  POST1 results may be  Â
 erroneous unless you RESUME from a Jobname.DB file for this su-bstep. ÂThe calculation set is the following:
    nlgeom,on         Â    solcontrol,on       Â    lnsrch,off        Â    eqslv,pcg,,2       Â    !eqslv,sparse,,2      Â    pcgopt,5,,,,,incore    Â    pred,on          Â    autots,off        Â    kbc,0           Â    nropt,full,,on      Â    neqit,200         Â    cnvtol,u,1,0.02,2     Â    cutcontrol,plslimit,5  Â    nsubst,1,1,1       Â    allsel,all    outres,all,none    outres,all,allÂHow can I fix this warning?ÂBest regardsÂJacquelineÂ
October 20, 2023 at 6:45 am
erik.kostson
Ansys EmployeeÂ
Hi
I think all it says is that your .db and .rst results file are different (BC or mesh), and hence gives you the warning.
As it says use resume before restart, or when you enter POST1 to load the correct .db sub step matching the .rst file you are looking at. I hope this helps.
Also this should be of help and explain things perhaps:
https://simutechgroup.com/separating-db-database-file-from-rst-file-contents/
Erik
- The topic ‘Error Ansys APDL when reading the results’ is closed to new replies.
