September 16, 2021 at 1:52 am
momchil
SubscriberHi I am trying to run older scripts, and I get an error that "addfdtd is not a valid function or a variable name" -
is addfdtd removed from MODE 2021 R1 release?
I cannot find FDTD object under Simulation also, why is that?
September 16, 2021 at 2:00 ammomchil
SubscriberHi,
answering my own question - the error is due to improper project start - when running scripts with FDTD engine command (i.e. addfdtd) start the launcher and open a "New FDTD Project".
The error was due to my MODE application starting the default project with EME solver instead.
September 16, 2021 at 5:01 pmGuilin Sun
Ansys EmployeeYou are right that if you use script you will need to launch the proper project first. If you manually open a new project from "File", you will be able to open any solver from the launcher as the recent a few versions have this compacity.
November 17, 2023 at 7:11 amsimenew.assefa
# Import the refractive index data for each material
importmaterial(glass, "SiO2.mdf"); # Replace "SiO2.mdf" with the appropriate MDF file for glass
importmaterial(ito, "ITO.mdf"); # Replace "ITO.mdf" with the appropriate MDF file for ITO
importmaterial(zno, "ZnO.mdf"); # Replace "ZnO.mdf" with the appropriate MDF file for ZnO
importmaterial(p3ht_pcbm, "P3HT_PCBM.mdf"); # Replace "P3HT_PCBM.mdf" with the appropriate MDF file for P3HT:PCBM
importmaterial(moo3, "MoO3.mdf"); # Replace "MoO3.mdf" with the appropriate MDF file for MoO3
importmaterial(al, "Al.mdf"); # Replace "Al.mdf" with the appropriate MDF file for Al# Define the layer thicknesses (nm)
thickness_glass = ...;
thickness_ito = ...;
thickness_zno = ...;
thickness_p3ht_pcbm = ...;
thickness_moo3 = ...;
thickness_al = ...;# Create the multilayer structure
stack = stack();
addlayer(stack, thickness_glass, glass);
addlayer(stack, thickness_ito, ito);
addlayer(stack, thickness_zno, zno);
addlayer(stack, thickness_p3ht_pcbm, p3ht_pcbm);
addlayer(stack, thickness_moo3, moo3);
addlayer(stack, thickness_al, al);Calculate the absorption spectrum
spectrum = spectrum(lambda);
addpower();
addanalysis();active layer.lsf;
Error: C:\Users\Newaye\Desktop\active layer.lsf.lsf line 13: importmaterial is not a valid function or variable name.CAN ANY ONE HELP ME HOW TO RUN IT?
Viewing 3 reply threads- The topic ‘Error: addfdtd is not a valid function or a variable name’ is closed to new replies.
4167
1487
1338
1188
