June 5, 2023 at 2:09 pm
Nadiia Kopiika
SubscriberI have been working on simulation and everything was ok. Suddenly, when starting Mechanical I have got Error 80004005 if (report Preview Pane.Pane.Selected). I have tried to create the new project and reinstall the software, but it did not help. Does anyone knoe how to resolve it?
June 12, 2023 at 2:51 pm
Rajeshwari Jadhav
Forum ModeratorHi Nadiia,
Please try this solution :- https://support.ansys.com/KnowledgeResources/Solutions?solutionIdentifier=sol2055276&productName=ANSYS+Mechanical&productFamily=Structural%20Mechanics1. Close all Ansys applications on your machine.2. Open My Computer or Run3. In the address bar > type %appdata% and hit enter > Rename the folder Ansys to Ansys.bak4. Launch Workbench again (a new Ansys folder will get created in %appdata%).ÂLet me know if this solution works for you. -
June 13, 2023 at 11:43 am
Nadiia Kopiika
SubscriberHi. I have found anoher solution to this error. I have renamed all the folders in AppData adding "_old" in the end and it worked.
- The topic ‘Error 80004005 if (report Preview Pane.Pane.Selected)’ is closed to new replies.
1487
1318
1156
