October 16, 2025 at 9:47 am
Roberto
SubscriberHelloÂ
There's this problem in version 2025R2.
When I save a STEP file with the sheet metal file inside (see video), it also saves the development.
This didn't happen in version 2024 and earlier. Is it possible to implement the same behavior as in version 2024 for versions after version 2025?
This is because it's very inconvenient, and it always saves the empty component (this also needs to be fixed).For all sheet metal users, this is a big problem, as importing the STEP file results in two overlapping solids: the bent one and the unfolded one. For CAM bending programs, we need a STEP file that contains only the geometry of the bent part, otherwise the program cannot import the file.
video link https://app.screencast.com/PXBWg1elpjkSc
October 16, 2025 at 10:34 pm
Essence
Ansys EmployeeHello,
Ansys employees are prohibited from opening any links. Therefore, kindly attach screenshots about the issue(s) you are facing.
October 17, 2025 at 12:21 pm
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4102
1487
1318
1156
