LS Dyna
LS Dyna
Error 41434 (SOL+1434) Error encountered in SPH neighborhood search routine.
    • Tim T
      I encountered the following error while using the Sph algorithm for solving:*** Error 41434 (SOL+1434)
      Please check mest### file for detailed information.
      The version of the solver I am using is R12.2.1 mpp,What should I do to solve this problem?
    • Reno Genest
      Hello Tim,
      Have you checked in all the mesXXXX files for a more meaningful error message? In MPP LS-DYNA, each core will write its own mesXXXX file. For example, if you run on 4 cores, you will have mes0000, mes0001, mes0002, and mes0003 in the working directory. A meaningful error message may be on only one of the mesXXXX cores depending of which core encountered the error.
      If you ran on many cores in MPP, we have a webapp to help you extract error messages from mesXXXX files:
      https://nagasairam112-check-dyna-errors-error-dyna-check-rq20je.streamlit.app/
      You can drag and drop all mesXXXX files to this webpage to extract error messages.
      Let me know if this helps or not.
      Reno.
    • 2551450404
      I also had the same problem in simulating the problem with sph on the mpp solver, and the same error was reported. Have you solved it?
    • SatarLPrasanna
      how to deal with this type of error if isph analysis is done
    • Reno Genest
      Please create a new thread for the iSPH question.
      Thanks,
      Reno.
Viewing 4 reply threads
