LS Dyna
LS Dyna
Error 30281
    • kranthi balusu
      I am receiving this error when I try to run an model with SPH part
      __________
       *** Error 30281 (INI+281)
           SPH initialization
           Material number 5
           material type 20 is not implemented
      __________
      I don't understand this error because material number 5 is not material type 20 in my model.
      I would appreciate every suggestion.
      Thanks,
    • Ram Gopisetti
      what was the material model inferred there ?
      Did you check the compatibility to the SPH and material in the following link
      https://lsdyna.ansys.com/dynamat/
      Cheers, Ram
    • kranthi balusu
      Thanks for your response, ram. Saving the k file VDEV version instead of V970 solved this problem.
      I assigned this material (rigid body mat 20) to an SPH body. Material 5 was an elastic material definition that I used for another part.
  • The topic ‘Error 30281’ is closed to new replies.
