December 9, 2022 at 12:32 pm
ross smith
SubscriberHi, does anyone know what these errors and warnings mean?
I am submitting my input file to the HPC servers and this is the first time I have encountered the error. i have been using the same PBS scripts previously without any issues.
*** ERROR *** CP = 4.489 TIME= 22:02:15
Missing separator between two fields.*** ERROR *** CP = 4.491 TIME= 22:02:15
The above error occurred processing field=
725FFBA5-37FA-45C3-840A-B9ACA5016EB8
Line= MP,UVID,1,725ffba5-37fa-45c3-840a-b9aca5016eb8.***** WARNING *****
Undefined parameter used in field 4 (725FFBA5-37FA-45C3-840A-B9ACA5016EB8)
Line=MP,UVID,1,725ffba5-37fa-45c3-840a-b9aca5016eb8*** ERROR *** CP = 4.491 TIME= 22:02:15
The material property with label= UVID is not known. For nonlinear
materials try using the TB command. The MP command is ignored.Thanks
December 14, 2022 at 9:21 pm
John Doyle
Ansys EmployeeI am assuming you are trying to run something in Ansys MAPDL solver in batch.
It appears to be choking on the MP command.It does not appear to recognize the label "UVID" as a supported material property.
Also, "725FFBA5-37FA-45C3-840A-B9ACA5016EB8" is not a recognized numerical property or parameter.
Please refer to the MAPDL commands manual for MP and TB for details on what Labels are supported and for supported command syntax. I have no idea how this worked without issues in previous runs. It seems like something is missing upstream.
March 18, 2023 at 12:22 am
Nick Estrada
SubscriberMake sure the versions are the same. This happened to me when I tried to run a 2021r2 .Dat file in 2020r2
- The topic ‘Error.’ is closed to new replies.
3622
1303
1122
1068
1008
