June 3, 2024 at 4:38 pm
June 4, 2024 at 6:03 pm
igandiko
Ansys EmployeeThis look like a generic keyword read error. Do you have *parameter any chance with hpres? What happens if you change the name?Â
June 4, 2024 at 6:16 pm
igandiko
Ansys EmployeePlease also check if there are multiple functions with the same name (maybe in the include files?)
June 4, 2024 at 6:20 pm
Ariq Indra Pratama
Subscriber-
June 5, 2024 at 5:12 pm
igandiko
Ansys EmployeePlease locate the ls-dyna input file writen by WB LS-DYNA. It should be in the solution directory (right click soluton > open solver directory > input.k). Please check *DEFINE_FUNCTION cards in the file. Most likely you have multiple *DEFINE_FUNCTION cards with same name (hpres) and ls-dyna solver is triggering an error. Function names should be unique. I think WB is using same function name for all objects defined for hydrostatic pressure.Â
A workaround is to just add one object and for the second one, use keyword snippet to manually added *LOAD_SEGMENT and *DEFINE_FUNCTION cards while making sure function name is unique.Â
- The topic ‘Error 10907 (KEY+907)’ is closed to new replies.
4597
1495
1386
1209
