August 7, 2024 at 10:07 am
August 8, 2024 at 11:02 am
V.P
Ansys EmployeeHi,
This can be due to high velocity flow inside the domain, can you recheck the inlet conditions?
Also, try running the case using Double Precision.
August 13, 2024 at 10:10 am
Petros
Ansys EmployeeHi,
Is the operating point close to one of the speed curve limits? If so, can you try using exit corrected mass flow for the outlet?
Also what are your current boundary conditions?
Thanks
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
1495
1386
1209
