January 10, 2024 at 10:07 pm
Rakshith Badarinath
SubscriberWhat is the difference between Equivalent Total strain and Max Principal strain (EPTO1 expression used in user-defined result)? When to use either of these and Is there a criteria to decide which one to use for analysis?
January 11, 2024 at 9:34 am
ErKo
Ansys EmployeeSee here:
EPTO1 means total maximum principal strain (so epsilon_tot_11)
The equivalent total strain is as per the help manual:
' The equivalent total strain gives a total value of strain in any engineering body. The total strain components are calculated by addition of components of elastic, plastic, thermal, and creep strains and then equivalent total strain is calculated from total strain components. This result type is available in Mechanical only if at least one of the other three strain results is available for post processing'
Help manual:
See below how to open the help link above:
See also this discussion:
/forum/forums/topic/strain-von-mises-vs-principal-for-brittle-material/
All the best
Erik
January 11, 2024 at 10:42 am
Sampat Kumar
Ansys EmployeeHi Rakshith,
As Erik correctly mentioned the difference between the equivalent strain and maximum principal strain, you can follow the attached link.
The sum of individual strain components (elastic, plastic, thermal, creep) for an engineering body can be expressed as the equivalent total strain.
Equivalent total mechanical strain (output using EPTO, EQV). The total equivalent strain is calculated based on the von Mises. EPTO1,2,3 means total maximum principal strain.
Sampat
- The topic ‘Equivalent Total Strain vs EPTO1’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4492
1494
1376
1209
