February 29, 2024 at 9:06 am
sachin.kumar
SubscriberHi,
I have studied one paper in which they mentioned about the equivalent plastic strain range for one thermal cycle as a failure criteron.
Can anyone explain how to calculate equivalent plastic strain range and what does it mean
February 29, 2024 at 10:35 am
Avnish Pandey
Ansys EmployeeHi,
Can you share what kind of analysis you are interested in to perform on Ansys and on which platform (APDL, Mechanical, LS-Dyna etc.)
Also, if it is possible can you put the link of the paper that you are talking about?
You can determine Equivalent plastic strain for a non-linear problem in Mechanical by inserting its probe by right clicking on the Solution settings.
Various probes for different analysis types are available in Mechanical.
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/ds_probe_overview.html
Best !
February 29, 2024 at 10:52 am
sachin.kumar
Subscriberpaper link: https://www.sciencedirect.com/science/article/pii/S1350630723004806
I am using ansys workbench toolÂ
Equivalent plastic strain i know very well
could you explain about the Eq. plastic strain range
March 1, 2024 at 1:36 pm
Avnish Pandey
Ansys EmployeeHi,
Extract the six components of Total Plastic strain at two time instances and then take the difference.
It will represent the range that you are looking for.
Hope this helps. All the best!!
March 2, 2024 at 5:30 am
sachin.kumar
Subscriberok,
- The topic ‘Equivalent plastic strain Vs Equivalent plastic strain range’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
4162
1487
1318
1170
