September 10, 2023 at 3:44 pm
Selawe97
SubscriberHelloÂI am trying to do a simulation of the melting of PCM in metal foam, using the melting/solidification model and nonequilibrium thermal model (porous media) in fluent. I found in the literature that they use fluent. and the equations they wrote in the literature are as followWhen I checked the fluent theory guide for the equations used in the Melting/Solidification model. (enthalpy porosity method) is used as follows for energy equation and momentum source term:
Also for energy and momentum equations for nonequilibrium thermal model as per fluent guide
The question is what the equation will look like when I activate the Melting/Solidification model and nonequilibrium porous media together. the previous equations are shown for each model separately, and I see some discrepancies between these equations and the equations in the literature so is there a special treatment I should consider? how i can ensure that when I activate both models, the equations will be similar to those in the literature?
September 11, 2023 at 4:45 am
SRP
Ansys EmployeeHi,
The equations mentioned in the literature are for metal foam where it consider the porosity in the metal foam whereas in fluent it describes the equation for phase change of complete material based on enthaphy porosity technique.
Thank you.
September 11, 2023 at 5:04 am
Selawe97
SubscriberThanks for your response
But what is the equation used in fluent when i use melting/soldification model and activating porose zone option of fluid cell zone ( non equilibrium thermal model porous media)
Thanks
September 11, 2023 at 1:37 pm
Forum ModeratorFluent will then use both sets of equations as the solidification model isn't linked to the non-equilibrium model.Â
September 12, 2023 at 8:08 am
Selawe97
SubscriberHello
Just to make it clear to me, it will use the two sets of equations as in the literature(the fisrt immage) or they are not coupled together?and special treatement is required?
September 12, 2023 at 12:36 pm
Forum ModeratorIt will use the two sets of equations in the Fluent documentation. However the solidification model freezes the flow in the "solid" cells so I'm not sure if you'll get what you want when you also add in the non-equilibrium model.Â
- The topic ‘Equations used in fluent’ is closed to new replies.
5719
