Equation in UDR for results at distinct load steps.
    • Jur Bokkers
      Dear,
      I know that in User Defined Results I can add an Expression to calculate values. I want to determine the MaxPrincipal - MinPrincipal, but at distinct load steps. In total I have 5 load steps. The calculation should be MaxPrincipal(t=5) - MinPrincipal(t=3). Is this even possible? And for each single node within my Named Selection?
      Thanks,
    • erik.kostson
      Hi
      You should be able to use identifiers in the MaxPrincipal(t=5) and MinPrincipal(t=3) results, say called maxt5 and mint3 respectively, and then use those (identifiers) in a user defined result expr:
      maxt5  – mint3
      All the best
      Erik
  • The topic ‘Equation in UDR for results at distinct load steps.’ is closed to new replies.
