November 15, 2021 at 9:20 am
rajendrapor
SubscriberFor a case of flow and heat transfer through a porous media (or even a simple pipe), what is the entropy generation formulation used by Fluent? (Viscous dissipation is neglected in the case). The flow is laminar. Similarly, for pure conduction cases any refrence for the same.
November 16, 2021 at 1:46 pmKishan Konannavar
Ansys EmployeeHello
Could you share in what context are you asking this question, as in, what specific problem are you trying to solve?
Thank you
Kishan
November 17, 2021 at 11:48 amrajendrapor
SubscriberThanks for the prompt response!!
I wish to know the equation(s) Fluent uses to calculate the entropy generation for a case of flow (Delta P) and heat transfer (conduction & convection) through a porous media for laminar flow (viscous dissipation is neglected). Some references would also be highly appreciated. Since, without any proper reference in the user manual of Fluent (or anything similar) about the rate of entropy generation, one cannot adopt Bejan's formulations.
November 17, 2021 at 2:00 pmKishan Konannavar
Ansys EmployeeHello
Fluent does not calculate the entropy generation, it is a derived quantity. You might want to look into references for the exact formula to derive the same. Unfortunately I would not be able to point you to that. The general formula would be: dynamic viscosity *(shear strain rate)^2. You may have to extract the quantities necessary for the calculation of the entropy generation. You might want to look into UDFs for that.
Thank you
Kishan.
November 18, 2021 at 9:52 amrajendrapor
SubscriberThanks for the response!!
The equations are well established and are given in A. Bejan's books/papers. So, I can write the UDF for post processing the results in form of entropy generation.
March 21, 2022 at 1:59 amMONAGAD
Subscribercould you write the entropy generation equation you use?
March 21, 2022 at 2:00 amMarch 21, 2022 at 10:56 amRob
Forum ModeratorCheck the Custom Field Functions, there are some derivative available there. Otherwise you may need a UDF. Expressions are becoming more powerful, but I don't think they can handle the derivatives etc just yet.
March 22, 2022 at 12:49 amMONAGAD
SubscriberThanks for your reply, I appreciate it, I find that it is called viscous dissipation term in the fluent theory but still can't find this term directly in fluent, I just find turbulence dissipation but not viscous dissipation, Do you have any suggestion?
March 22, 2022 at 11:03 amRob
Forum ModeratorCheck the general equations - I suspect it's part of the more general flow solver theory.
March 22, 2022 at 11:37 amMarch 22, 2022 at 11:41 amMONAGAD
SubscriberThis viscous term is also part of entropy equation, i can define all other parameters in this equation in user define function but this disipation term do not know from where get it
March 22, 2022 at 1:41 pmRob
Forum ModeratorIf it's not in the UDF manual we can't assist due to the Forum rules. Have you checked the header files?
March 23, 2022 at 8:50 amMONAGAD
SubscriberThanks again for reply,but what do you mean with the header files?
March 23, 2022 at 2:42 pmRob
Forum ModeratorThe .h files - they contain the macros.
Viewing 14 reply threads- The topic ‘ENTROPY GENERATION THEORY?’ is closed to new replies.
5964
1307
