September 19, 2023 at 9:43 am
n n
SubscriberHello,
where can i found the value of the enthalpy at melting (J/m3 ) in ansys additive ?
September 25, 2023 at 10:43 am
Zoi Stavrothanasi
Ansys EmployeeHello,
If you want to define the enthaly of a material you have to access the Engineering data, then sletect Thermal from the Toolbox and finally drag Enthaly and drop it in the property section. Hope this helps!
ZoiÂ
September 25, 2023 at 12:39 pm
- The topic ‘enthalpy at melting single bead parametric simulation in ansys additive’ is closed to new replies.
