Ensight hot iron palette from an image
    • desouzadacosta
      Hi all
      I have an thermography image with a hot iron color palette. How can I replicate that with Ensight ?
      Any clue from  the Ensight/Ansys people is very welcome.
      thxs
    • Kevin Colburn
      Color your part with the desired variable. Adjust the color palette for that variable (each variable can have its own color palette) by right clicking on the variable in the variable list and select "edit palette". In the Palette Editor, there are some tabs options. Click on the "Files" tab to get to the various palette file options. Search there for "hot metal", for example. Select the one you want, and click "Restore".
      Adjust Palette
      You can edit the RGB value of any of the colors used in the palette to suit your needs. Adjusting the range can also be used to align to specific colors needed.
      -Kevin
    • Karthik Remella
      Administrator
      Here is how you can edit Palette on a contour plot.
      • Create your contour plot and right-click on the legend. It will open the following dialog box.
      • Click on 'Edit Palette', which will take you to 'Palette editor' (screenshot below). Switch to the 'Files' tab. Please choose the palette that closely resembles what you want to compare with.
      I hope this helps.
      Best Regards,
      Karthik
    • Karthik Remella
      Administrator
      Kevin,
      You beat me to it by a minute. Thank you for posting the solution.
      Best Regards,
      Karthik
    • desouzadacosta
      Thanks Karthik and Kevin for the output. I am afraid the available palettes are not the same from the Flir thermographies (please google for flir hot iron thermographic images and you will see my point)
    • Keyur Kanade
      Can you please let us know which license you are using? Is it student version?
      Keyur
    • desouzadacosta
      19.2. I dont have admin privileges but,  it seems to be the regular license.
    • Keyur Kanade
      What is regular license? Is it student version?
    • desouzadacosta
      Student version and Ensight standalone
    • Keyur Kanade
      Which license you are using for EnSight standalone?
      Keyur
    • desouzadacosta
      Ensight Gold 10
    • Keyur Kanade
      EnSight is not included in student version. So I am asking if you are using student version or some other licenses?
      Keyur
    • LorenzoItal8
      Cool. I had pretty much the same question as the guy who asked this thread and your answer really helped. I tried using color palettes with https://create.vista.com/colors/palettes/80s-color-palette/ and I can tell you that it's really cool and convenient, the palettes are very high quality and the site is user-friendly.
Viewing 12 reply threads
  • The topic ‘Ensight hot iron palette from an image’ is closed to new replies.
